Switching LEDs using two analog channels and DAQ assistant
Hello there,
My goal of the project is to switch the channel of LED since I will have two solid state relays from a two channel power supply.
-Both channel supply 5V DC to the solid state relay. I am able to hook up one channel and supply the 5V to one of the SSR using DAQ assistant. However, my problem is with LabView that I am not too familiar with. I want to switch the LEDs on and off given to control two relays and two LEDs but I was not able to do so using case structure.
I have been searching online but was not able to find the examples that are similar to what I am doing. I attached the VI here can someone give me some guidence and direct me in the right direction. Thanks so much for all the help.......
Message 1 of 1
(1,769 Views)
