03-01-2017 05:21 PM
Hi there,
Then there are 3 possibilities.
1) your ccd.ini entries are bad
2) your driver tables are wrong
3) your controller is simply screwed up
Since those controllers are very old and Horiba does not support them anymore.
So if you've lost your original driver tables in the 'ccd' directory, then it's a mess. The gain settings are (to my flawful knowledge) specifically tuned to your device, so it doesnt help using mine.
Sorry for that rather negative answer but in the oast year, all of your ccd3000v controllers died.
JW
03-01-2017 06:14 PM
hello, i used the ini file and tables you provided in this forum, could be that those archives does not work for my ccd?
where i could find technical support about the creation of that tables?
additionally, making a debug of the CCD demo, i note not all archives are used, why?
thank you very much
03-01-2017 06:38 PM
Hi
Horiba does not give out any support manuals or information on that. Please try to find the original driver disc.
As for the lvlibs: I extracted the Horiba llb files and made lvlibs out of them. So there are the original files and my wrappers.
My ini file/driver tables should work for CCD3000V controllers (not necessary CCD3000 controllers). I tested them in my labs.
Best regards
JW
03-02-2017 03:11 PM
hello, can you or anyone post or send me the ccdload.ini and data tables (such as econvert.tab etc) for the CCD 3000, i lost all those files.
thanks.
03-02-2017 03:36 PM
Sure!
08-22-2018 06:00 AM
Dear JW-WSI,
Do you have information on what files from your CCD.zip archive are controller-specific?
I have a SpectrumOne CCD and two controllers. One is CCD3500, and I have a CD disk with all installation files. It used to work perfectly, but now I think that the controller is dead. The second controller is CCD3000, and it has no file. I tried to run my CCD with the second controller, it kind of works: I can read the temperature of the CCD, it shows coorectly room temperature and a cooling down process. And it shows 2^16-1 at each wavelength, when I measure a spectrum at room temperature (this is normal). Unfortunately, at low temperature is also gives 2^16-1. Only if the CCD is frozen, it shows lower levels with noise, but I think it is just noise from electronics, so the spectrum can not be measured.
Probably, it has something to do with how the controller interprets the analog signal from the CCD? P.S. The gain is the lowest.
08-26-2022
07:07 PM
- last edited on
08-29-2022
10:55 AM
by
NI_Community_Su
hello, would you please send the CD disk of CCD3500 . I missed such files. Thanks a lot.
