09-14-2010 01:21 PM - edited 09-14-2010 01:24 PM
Hello
I download 83732B driver and try to use it ,every time I open any library it alway call hp837xx_32.dll. How to fix this problem?
Wee
Solved! Go to Solution.
09-14-2010 01:36 PM
Did you see the 'Required Third-Party Installation' link? The dll was created by Agilent. You have to get it from them. Try this.
09-14-2010 03:38 PM
Do you mean that I need to download The IO Libraries Suite? an install to my pc?
09-14-2010 04:41 PM
Perhaps. You are looking for the instrument driver so try the 'VXI Plug&Play Driver'. I don't know what dependencies it might have so try installing just the dll (assuming it actually there) and see if you get any errors. If you do, then install the IO Libraries.
09-14-2010 04:55 PM
Hello Dennis Knutson
I did install 'VXI Plug&Play Driver' and try to open labview still program looking for dll file, then I did install IO Libraries but problem still there labview looking for dll so bad haaa...
Any suggestion.
09-14-2010 05:04 PM
Did you do a search for the dll? The Agilent installer may have put it in a different place than where the LabVIEW CLFN (Call Library function Node) expects it. If that's the case, right click on it and select Configure. You can then browse to the actual location.
09-14-2010 05:20 PM
Thanks Dennis Knutson I found that dll, and problem solve..thanks again..
09-05-2018 10:10 AM
Hello weerapol, I search this dll, can you tell where did you found it please ?
02-19-2020 01:18 PM
Would you or anyone, please tell me how to search .dll file?
03-02-2020 07:48 AM
It appears that the .dll for this series isn't available. The download for the driver contains .exe files that are probably self installers for older operating systems (i.e. Windows 3.1,95,etc.).
One alternative is to adapt the drivers available for the 836xx series, which may be close enough for some applications. This is not .dll dependent, so any differences could be edited out.
