Share COM device between two instances of application running on two computers
I'm waiting for some answers from Moxa about the NPort5150.
Thank you K C for this tip.
Message 11 of 13
(548 Views)
If possible, could you run a small LabVIEW program from the chamber that could act as a server and periodically post the chamber temp, program step and time remaining for that step?  We were able to do that for the Thermotron chambers.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 12 of 13
(540 Views)
FYI, I just found an interface from W&T that allows to define the port release delay (since the last message) from 1 second and uses XON / XOFF. This will suit my needs.
Message 13 of 13
(496 Views)
