06-20-2006 03:49 PM
06-20-2006 03:57 PM
06-20-2006 04:19 PM
06-20-2006 04:57 PM
06-21-2006 01:07 PM
Hello Aria,
I do not have the instrument to troubleshoot with, but I do have some suggestions to help you figure out what is going on. In troubleshooting, it is important to separate the hardware from the software. To determine if your logic in sending commands is correct you can use the Highlight Execution button in LabVIEW, to see when your data values are being read. If you can find nothing wrong in the software, then I suggest looking into NI Spy and seeing the commands that are being sent to and read from the device.
At the base of the driver it is simply VISA commands, so it may be worthwhile to send the command that is supposed to set the mode and then read the response using just VISA Read and Write to verify that the instrument is actually understanding the command.
I hope this helps, I am sorry I am not able to test the instrument to verify this command.
Angela
06-22-2006 02:43 PM
09-05-2008 08:11 PM
09-08-2008 08:17 AM
Hello Yll,
You will need to attach more than just the lvproj for us to see what you are doing. Please attach the smallest VI that reproduces the issue. Have you tried the troubleshooting steps that the other posters suggested/used? How do the examples work?
Cheers,
NathanT
09-08-2008 03:18 PM
Hi Nathan,
I found out that the right data was collected but it just did not display on the network analyzer. Thanks a lot for your reply.
09-09-2008 07:43 AM
Hello Yll,
I am glad that you realized what the problem was. In many cases data will not be displayed on the instrument if it is in remote mode or the instrument driver will explicitly turn off the instrument's display in order to make the instrument acquire data faster.
Cheers,
NathanT
