I'm using an NI 8431 8 port PCI serial board, NI driver version 1.8, with CVI 8.0 on a Windows XP Pro PC.
It appears to me that the timeout value I establish for the port using the rs-232 library SetComTime() is being ignored.
I set a purposely low value (say 2.0 seconds) and then issue a ComRdTerm(). The device (an HP34970A) takes about ten seconds to complete a measurement, with the ComRdTerm pending the entire time. I should think the read would time out. But it doesn't - the read returns without error when the terminating character is received some ten seconds or so later.
Has anyone seen this problem? Code below ... SerialConfig is a struct set up with config info including an element timeOut of type double, value 2.0.
Hayes
// Open the comport. If port is already open, OpenComConfig will close and reopen it.
if ((iStatus = OpenComConfig (SerialConfig.port,
SerialConfig.bitRate,
SerialConfig.parity,
SerialConfig.dataWidth,
SerialConfig.stopBits,
SerialConfig.inQueue,
SerialConfig.outQueue)) < 0) {
return HP34970_CONFIG_ERROR;
if ((iStatus = SetComTime (SerialConfig.port, SerialConfig.timeOut)) < 0) {
CloseCom (SerialConfig.port);
if ((iStatus = SetCTSMode (SerialConfig.port, SerialConfig.CTSMode)) < 0) {
if ((iStatus = SetXMode (SerialConfig.port, SerialConfig.XMode)) < 0) {
// Port is open, establish port number.
iHP34970Comport = SerialConfig.port; // Establish comport number.
then
if ((iStatus = ComRdTerm (iHP34970Comport, pszInString, HP34970_MAX_BUFFER_SIZE, NEWLINE)) <= 0) {
pszInString[0] = NUL; // return an empty string
return HP34970_COM_ERROR;
if (ReturnRS232Err() != NO_ERROR) {
pszInString[iStatus] = NUL; // make returned bytes into a string
