Serial/USB communication with Mbus via NImyRIO(Mbus-LabVIEW)
Hii everyone,
I want to read electricity meter(Mbus) with LV. I am new with this protocol. My connection is as follows: Mbus meter to NImyRIO via serial/USB connection and myRIO hardware is connected to PC.
I tried to send SND_NKE 10 40 00 40 16 (in string constant hex display- 1040 0040 16), however, I don't get any response. It should return E5, but I did not got any thing.
I attached my VI with this message.
My experience with this is not more. Hopefully someone can help me where I did mistake.
Message 1 of 8
(952 Views)
There's a forum thread (Problems with serial/usb communication with M-bus) where similar issue was solved.
Please take a look and see if it helps.
Message 2 of 8
(911 Views)
Hii nbabajan,
Yes, I have looked into it and tried,  but it did not help me.
Message 3 of 8
(905 Views)
Can you provide your M-Bus device documentation or specify what meter are you using?
Also, you're running the VI on MyRIO right?
Message 4 of 8
(882 Views)
Hii nababajan,
Yes I am running my VI on myrio. I attached the datasheet of Mbus device and pegelwandler(convert Mbus to RS485).
Message 5 of 8
(876 Views)
Hi again,
Thank you for provided documents, I'll try to figure the things up.
Meanwhile you can try using Modbus Library for LabVIEW (can install it using VIPM).
Message 6 of 8
(858 Views)
Hii nbabayan,
Yes, I know about Modbus library, but my meter works on Mbus protocol. there is a different version for Modbus available, but I don't have that. So I have to find solution for this Mbus protocol.
Message 7 of 8
(850 Views)
Accepted by topic author parthsuhagiya
Hii everyone,
I found the problem. when I put a probe on refnum after visa configuration, it showed me 9600 baud rate, I don't know why, because I made a constant of 2400 for that. than I deleted visa configuration VI and put a new. It is working now.
Thank you for your help, time and support and sorry for inconvenience that I created.
I attached the final VI.
Message 8 of 8
(842 Views)
