03-17-2018 03:28 AM
Hello, i have a GY 85 sensor that includes a gyro, accelerometer and compass, i am reading the data on arduino and i want to send it on labview. I am using the vi attached below, i feel like i did something wrong and i dont want to store the data in a file, i want to use the values in the same vi (real time).
i would really appreciate an answer!!!
P.S: should i send the data to labview or Myrio?
03-17-2018 05:07 AM
03-17-2018 05:28 AM
this is the arduino code. Sorry i'm a newbie in serial communication.
03-17-2018 05:39 AM
Hi
From the code it looks like the Arduino is indeed sending the data to the serial line.
Also I don't know why you are writing about the MyRIO. Do you have a MyRIO and are you using it in any way? The project is doing nothing at all.
I suspect that the express vi you call is also a MyRIO vi.
But maybe I'm wrong.
Can you send it also?
03-17-2018 05:53 AM
This vi is getting the data from the arduino, the buffer indicator shows the acquired data, but in that way i can't use them. Once i'm able to use the data ill copy the code to the original vi ( it won't be helpful here), so in short i want to use the data acquired form the arduino in the code
03-17-2018 10:17 AM
