Sending and receiving data from PIC18F4550
ok some success, now im using void  HidD_GetHidGuid(int32_t *arg1); function in call library function node,
and i could get the Device Interface GUID into the numeric indicator...
now what about other functions... for example, HidD_GetAttributes .. in order to use it, i must supply the IN HANDLE HidDeviceObject, as stated by the MSDN help..
however, i cannot find any example code where it could be extracted from... i have a driver code, but there they use another functions like HidD_GetAttributes = (PHidD_GetAttributes)GetProcAddress(hHID, "HidD_GetAttributes");
so... now i really need some example or explanation from someone who used to work with HID.DLL from LabView... though i understand already the overall process..
ok i will research more for now and wait for any replies
Message 11 of 25
(5,289 Views)
Accepted by cyrax
Ok, i was experimenting with all this stuff and now could make it run. So here is what i decided to use, when you install Microchip Solutions, in its install folder there is a folder USB Device - MCHPUSB - Generic Driver Demo, u should just compile it with MPLAB, and load the HEX file to the PIC18F4550. Then, im attaching my VI, u should put mpusbapi.dll in the same folder with this VI, and run it, also, dont forget to point all the Call Library Function Nodes in the VI to point to this DLL (cuz i think i had it in another folder).
mpusbapi.dll is a custom USB driver...it is i think even better solution than making it work with HID.DLL, also another good thing is that u can have another custom windows application work with this DLL, and the LabView VI is just talking to mpusbapi.dll
it is better than installing and messing with VISA... one driver - two applications (LabView, custom app).
the VI is working, i did not implement all the functions, but it works, it reads data from potentiometer and displays on meter.
p.s. there is also same example in the internet, but it was done with CIN, however, i think its easier and better to do it with Call Function Library node and DLL. I wish to find such an example before...but now i hope it would help someone.
thanx for replies and advices here!
Message 12 of 25
(5,244 Views)
forgot to say... u should also not forget to install the driver, it is located in that same install folder of Microchip Solutions..
thanx
Message 13 of 25
(5,241 Views)
I'm trying to open your file but it was created with LV 8.6 and i didn't got this version of LV.
It's possible to convert it on the version combatible with LV 8.5?
Thanks for replies
Message 14 of 25
(4,034 Views)
Mr. Bar,
There is a downconvert request thread here:
http://forums.ni.com/t5/LabVIEW/Downconvert-VI-Requests/m-p/1067229?requireLogin=False
Kyle Mozdzyn
Applications Engineering
Kyle M.
Message 15 of 25
(4,016 Views)
Hello
Thank for the replies!
Message 16 of 25
(3,998 Views)
