Screen capture of Tektronix MSO4104B using LabVIEW
How is he keeping records if you don't save the file? Are you requiring that the user take a screen capture of the unsaved image?
Message 31 of 49
(8,756 Views)
I suggest doing something like the following:
Save image as a temporary PNG file
Use function: "Read PNG file.vi"
Connect image data to function: "Draw Flattened Pixmap.vi"
Display picture in a "new picture" indicator
Message 32 of 49
(8,751 Views)
@Tournifreak wrote:
For this application, the user just wants to capture a copy of what is on the scope screen for record-keeping
Isn't that what saving to a PNG is doing?  I'm not seeing the need to put it in a picture control.
GCentral
Message 33 of 49
(8,744 Views)
Sorry to jump in but have a related question. I created a subVI with this save screen function a while back, but the file sizes for either bmp or png formats using a Tek DPO4054 are large 2.25MB. It wasn't a big issue then but now we're capturing lots of data. Is there a way to reduce the file size capturing scrnshots programmatically? Tek SW Open Choice saves them into ~70KB which is very good.
Thanks!
Message 34 of 49
(8,721 Views)
2.5MB is the uncompressed BMP file size. If you are trying to save as png, you must doing something wrong. PNG files should be well under 100kB. Double check your scope image format command.
Message 35 of 49
(8,713 Views)
I fully agree that you are not doing something right.  The PNGs come in a lot smaller than BMP.
Make sure you set the format in the scope to output a PNG.  I also recommend turning ON the Ink Saver (turns the black background to white).
Check out this post that I made for the commands that I use.  Again, the PNGs should be way smaller than 1MB.  The 70kB seems quite reasonable.  If you are still having problems, upload your VI to see if we can find something wrong with it.
GCentral
Message 36 of 49
(8,708 Views)
Here's the code I'm using, I'll try the commands shown on your examples.
One more thing is that screen shots saved using flash drive in the oscope are correct in size.
Thanks.
Message 37 of 49
(8,688 Views)
Try this:
Message 38 of 49
(8,682 Views)
hi Gibson,I also face the same problem,but there is a little difference.I use Ethernet interface connect my scope to PC,my scope type is TDS3032,when using the same code as yours(just modify the connect interface thpe),but  i didn't work.can you capture you screenshot with a Ethernet interface?
Message 39 of 49
(8,600 Views)
Check out my post here.  I made that code specifically for the TDS3034 (same family as your TDS3032).  My last project used Ethernet to communicate with the oscilloscope and it worked just find as is.  To be safe, you could change the port to use "ETHER" instead of "GPIB".
GCentral
Message 40 of 49
(8,594 Views)
