Rs-232 digital potentiometer using SPI and USB-6008
Hi
why can't it work?
and it seems you really are in a hurry after a few weeks silence
greetings from the Netherlands
Message 11 of 19
(2,760 Views)
i tried a lot,it can not change the value of resistence of digi pot mcp41010..can you give me the right programme...
Message 12 of 19
(2,755 Views)
Hi Albert, Sorry I think there is some confusion.Smiley Happy Its another user who seems to be in a hurry after not myself.  I haven't had the chance to look back on it and it seems like I might not need it after all as I just purchased a couple of ICs that can better solve my problem.
Ankitsharma. I suggest using possibly the 7555 as your clock signal
Cheers,
Darren
Message 13 of 19
(2,749 Views)
can you briefly tell me,how can i use 7555 to generate the clock
Message 14 of 19
(2,747 Views)
Perhaps you should consider actually looking at a datasheet?
Message 15 of 19
(2,729 Views)
sorry Darren, did not look deep enough
Message 16 of 19
(2,717 Views)
hello
I know this is a fairly old post but I have a similar problem to control digital potentiometer with USB 6008 now. I also use SPI digpot
Did you succeed to change digital potentiometer resistance with USB 6008 using RS232? Can you give me clues about how can I do it? I don't quite understand with the attached files in this thread
I'm very stuck now
thank you
Message 17 of 19
(2,595 Views)
or did you just use arduino?
Message 18 of 19
(2,592 Views)
Hi kamil8,
To be clear, are you using LabVIEW, or another NI software product to communicate with the digital potentiometer, or is this a separate program using the DAQmx API?
I might suggest making a new thread for your question so that other forum responders can see that you have a new question and be more able to help you out, even if the question is similar (as you said, this is a fairly old thread).
Message 19 of 19
(2,571 Views)
