05-24-2012 04:01 PM
05-25-2012 12:03 AM - edited 05-25-2012 12:05 AM
i tried a lot,it can not change the value of resistence of digi pot mcp41010..can you give me the right programme...
05-25-2012 01:48 AM
Hi Albert, Sorry I think there is some confusion. Its another user who seems to be in a hurry after not myself. I haven't had the chance to look back on it and it seems like I might not need it after all as I just purchased a couple of ICs that can better solve my problem.
Ankitsharma. I suggest using possibly the 7555 as your clock signal
Cheers,
Darren
05-25-2012 02:01 AM
can you briefly tell me,how can i use 7555 to generate the clock
05-25-2012 06:33 AM
Perhaps you should consider actually looking at a datasheet?
05-25-2012 03:09 PM
02-21-2013 05:45 PM
hello
I know this is a fairly old post but I have a similar problem to control digital potentiometer with USB 6008 now. I also use SPI digpot
Did you succeed to change digital potentiometer resistance with USB 6008 using RS232? Can you give me clues about how can I do it? I don't quite understand with the attached files in this thread
I'm very stuck now
thank you
02-21-2013 06:19 PM
or did you just use arduino?
02-22-2013 09:11 AM
Hi kamil8,
To be clear, are you using LabVIEW, or another NI software product to communicate with the digital potentiometer, or is this a separate program using the DAQmx API?
I might suggest making a new thread for your question so that other forum responders can see that you have a new question and be more able to help you out, even if the question is similar (as you said, this is a fairly old thread).
