Rohde & Schwarz SMBV100B - Generate signal through Labview
The Initialize Vi is in this path
C:\Program Files\National Instruments\LabVIEW 2020\instr.lib\rssmb
Message 11 of 16
(1,646 Views)
While my path is
C:\Program Files (x86)\National Instruments\LabVIEW 2020\instr.lib\Rohde&Schwarz RF Signal Generator
So we clearly loaded different implementations.
Please try the LabVIEW 2015 installation. It works for higher versions as well.
You only should give it enough time to compile all vi's
Message 12 of 16
(1,637 Views)
Hellou,
At first, thank you for your attention. It is realy helping me in this task.
I get that you mannage to use the signal generator, but I have a vector signal analyser, thats why I'm using this other blocks.
Message 13 of 16
(1,618 Views)
If I try to use the Signal Generator block, I get this
Message 14 of 16
(1,615 Views)
Do you have SMBV-K131 option? If so, the current driver limits its use to SMW200A. New version coming at the end of Jun will fix that. In the meantime, do the following:
In the Configure Error Checking.vi switch the Option checking OFF. Then you're good to go.
Milo
Message 15 of 16
(1,611 Views)
Hi
Misunderstanding everywhere. Sorry, but glad R&S finally gave a solution.
Message 16 of 16
(1,572 Views)
