Restarting serial communication after disruption
I am using a USB to serial converter to communicate to a PLC inside a while structure.
I am configuring the serial port before entering the loop.
The communication is fine...there is no issue with that.
Now whenever I unplug my USB-to-serial device the loop continues to execute unless I use the 'STOP' button to forcibly stop the loop. Only after the loop stops executing , the error dialog box is thrown.
Can anybody guide me in modifying my program to the achieve the following:
  1. The while loop exits as soon as the USB-to-serial converter is unplugged.
  2. Any means of restarting the VI after restoring the USB-to-serial converter.
Thanks in advance.
(5,150 Views)
I have used the unbundle function to read the error status & exit the while loop.
Attaching the edited version.
But my second issue is still unsolved.
(5,143 Views)
Put another While loop around all of your code.  Have it stop when you press the stop button.
(5,141 Views)
Thanks.
The while loop around the code works fine , but the outer stop button does not stop the execution.
I have to press the outer stop button then the inner stop button & then the outer stop buttoon once again to exit from the program.
(5,137 Views)
Only one stop button in the inner while loop does the trick....
(5,126 Views)
