Resource Manager has encountered a serious problem and needs to close
After loading the .NET 2.0 framework, resman no longer runs to completion. It locks up.
When it reaches "Initiating normal operation" on the status line, the Microsoft error box appears:
VXI Resource Mananger has encountered a serious problem and needs to close.
We are sorry for the inconvenience.
The error signature accessed through the error box is:
AppName: resman.exe AppVer: 4.0.0.209 ModName: niresmanengine.dll
ModVer: 4.2.1.47 Offset: 0000eb89
I removed VXI 3.3.1 and then re-installed it - but to no avail.
I tried to attach the error file that is sent to Microsoft, but this message could only accept 5000 characters.
Any help would be greatly appreciated.
Thanks!
TestStand 4.2.1, LabVIEW 2009, LabWindows/CVI 2009
(3,650 Views)
Hi Believer, Check out the following knowledge base.
Resman Crash Knowledge Base [broken link removed; article no longer available]
This should help you out. If it doesn't, just let us know and we'll be happy to help further.
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,627 Views)
