04-20-2021 03:03 AM
Hi, I am new and have task to replace E4440a spectrum Analyzer with N9030 Signal Analyzer. What sequence or steps do I need to take. E4440a is installed and programmed in an ATE. Do I need to rewrite all VIs?
04-20-2021 09:17 AM
It would depend on whether the drivers are different for both instruments. If they are different and the VI based APIs are used in your test program, unfortunately, you've to replace every single call of the old driver with the new driver.
