12-21-2011 10:22 AM
I was trying to setup a remote experiment control VI. After using the web publishing tool and save the file into root directory, i was able to access the front panel of my VI using browser on the my control PC.
When i try to access using another PC(client), the Webpage was able to be loaded with the knob button working correctly but the image capture by my USB camera is not showing.(The image display indicator is there, just without the image). However when i look at my control PC, the image from the camera is showing at the front panel.Can someone help me? thanks.
01-17-2012 10:59 PM - edited 01-17-2012 11:00 PM
As we all konw, the data of an image is different from the other LabVIEW data, and can't be directly browsed on the web through the Remote panel. I think if you want to remotely browse the image captured by your USB camera, you have to convert the data of the image, or use some third -party ocx.
