From Thursday, May 23rd (05:00 PM CDT) through Friday, April 24th (1:30 AM CDT), 2024, ni.com will undergo system upgrades that may result in temporary service interruption.
Regulation with pci 6221
I'm planning on developing an application for regulating a hydraulic system. Typically the regulation loop (VB/VB.NET) will read 10 AI-channels and based on the measured values a new AO-signal will be generated. What kind of speeds can I expect with the PCI-6221? The system will need about 100Hz two operate correctly. I ask because I have no experience when it comes to communiaction and latency regarding the PCI-bus.
The system will be developed in either VB or VB.net.
All suggestions are welcome
Øyvind
(2,792 Views)
from the datasheet, your PCI card has an output rate of 833 kS/s (833000 Hz).... hum, and your setup requires about 100Hz.
I can tell you: the hardware is MUCH faster than what you need and won't limit your application!
Nicolas
(2,711 Views)
