12-23-2011 10:18 PM
I have MS2601B spectrum analyzer (anritsu), I want to read measurement data through the GPIB from MS2601B.MS2601B can connect with GPIB and if change the PID of MS2601B manually(using front panel) and MAX show that change of PID.
But when I write or Query command like "INI \n" or "*IDN?" ,using "NI-488.2 Communicator",I get EABO error, I also try other commands too but unable to get any response.
Structure of commands written in manual is
WRITE @101:"CNF 1MZ"
WRITE @101:"INI"
I am new to labview and spectrum analyzer.SO may be I am doing some kind of mistake. Does anyone know correct format of command for the MS2601B and guide me how to get the data from the instrument by GPIB?
I find relative article but unable to solve it till now ,
I am using "NI-488.2 Communicator", sample code given for .net for sending commands.
I attached screen shot of MAX with error and Version detail .
Any kind of assistance will be appreciated
Thanks in advance
01-04-2012 01:44 AM
Within MAX did you do a scan to find all instruments connected to the GPIB?
01-04-2012 02:00 AM - edited 01-04-2012 02:03 AM
I downloaded the driver from NI and it seems to what (\r)CR (\n)LF sent with every command. are you sending this.
05-13-2013 08:46 AM
i've the same problem.
did you solved it?
Best regards
Daniele
