Read data from a Fluke 289 multimeter using LabVIEW
Hi Widhi,
I checked your program in my computer and it ran good without problems. It runs in windows xp, probably you have hardware problem.
Message 21 of 39
(5,099 Views)
I checked  your program fluke289.vi and ran good, I used labview 9 sp1 under windows xp.  Probably you have hardware problems.
Best Regards,
Message 22 of 39
(5,090 Views)
sorry for reactivating this old thread, but I still have a problem. Does anybody of you know, how to read the full log out of the Fluke 289 DMM? I would like to read the logged measurements, too, not just the current ones.
Message 23 of 39
(4,740 Views)
Try reading the programmer's or owner's manual for this instrument.
Message 24 of 39
(4,736 Views)
Try failed.
It's not mentioned in the manual. You should use FlukeView to download the logs, but I would like to do it with an own LabVIEW program.
Message 25 of 39
(4,731 Views)
Then you can use NI-Spy/NI-Trace to capture the undocumented commands.
Message 26 of 39
(4,729 Views)
...which is also not possible for me as I don't have the original Fluke software... 😞 (which is quite expensive)
Message 27 of 39
(4,709 Views)
If you dont have this Flukeview, then you need to talk to Fluke.
Message 28 of 39
(4,706 Views)
Quite expensive????
$210 for FVF with cable is "expensive" ????
Message 29 of 39
(4,704 Views)
Yes if you don't need it and already own the cable. And if you already payed about 600€ to Fluke for the instrument and the cable.
So back to topic: is there anybody who knows the protokoll?
Message 30 of 39
(4,694 Views)
