Raspberry Pi: Failed to connect to the target
Hello friends,
                     I am using Raspberry Pi 2 B and LabVIEW 2020 Community Edition. I want to connect both of these using different procedures available online. But still, I am getting this error 'Failed to connect to the target'. For Raspberry Pi, I am using a 16 GB SD card with an installed OS with a Desktop version. I have gone through Tool>MakerHub>LINX>LINX Target Configuration and installed LabVIEW on Raspberry Pi (image 1). After installation, the Window showed my 'Installation Completed Successfully (image 2). But the installed version is not shown (image 2). Still, I proceed further and went to the example. When I run the code and tried to deploy it. It showed an error 'Failed to connect to the target' and connection failed (image 4). I could not deploy LabVIEW code to Raspberry Pi.
Can anyone help me to resolve this error? (Attached Images)
Hardware: Raspberry Pi 2 Model B vi:2
Software: LabVIEW 2020 Community Edition
(562 Views)
You should post to the separate Hobbyist Toolkit board. There are more people knowing about Raspberry Pi with LabVIEW than here. But Community Edition 2020 is quite old and had indeed a few trouble. Newer versions don’t guarantee success but there are some people who have discovered problems and posted bugfixes and workarounds and not all of them might apply exactly to 2020 if you are not a well versed LabVIEW and Raspberry Pi buff.
Rolf Kalbermatter
My Blog
(488 Views)
