11-06-2006 10:55 AM
11-06-2006 11:34 AM
11-06-2006 11:38 AM
11-06-2006 11:43 AM
11-07-2006 04:18 AM
Thanks, that's the code I'm using for transmit. Anyone using it should note the VISA read in "LVRT Serial Write.vi" should be set to synchronously, (change by right-click and note watch symbol is removed from top-right corner).
I'm stuck on LV7.1 for this project, I would be extremely grateful if you could “save as” 7.1 or print the
My resulting cRIO RS-232 implementation will be shared, promise.
11-07-2006 10:26 AM
The link I posted earlier includes both a Transmit and Read example. The direct link to the Read example code is
ftp://ftp.ni.com/pub/devzone/epd/fpgaserialread.llb
11-07-2006 10:44 AM
11-28-2006 12:10 PM
11-29-2006 07:14 AM
Hi fpga,crio,
What are the model numbers of the parts that you have? With Analog input DAQ devices there is usually an onboard ADC (analog-to-digital) converter. The ADC is an electronic device that converts an analog voltage into a digital number that you can send to the computer for interpretation using the computer I/O interface circuitry. The Analog input circuitry combines with the ADC to acquire an analog signal so that you can measure the level, shape or frequency of that signal. With analog input you are basically converting real world voltages into digital values that your computer can display and analyse.
Check this link out, to learn more about Analog input and DAQ:
http://zone.ni.com/devzone/cda/tut/p/id/3216
I'm not sure what you mean by "sub" or "picture"? can you elaborate on this.
Kind Regards,
Kurt
NIUK Applications Engineer.
05-24-2010 03:48 PM
