02-09-2011 09:59 PM
Hello. I'm hoping there is an easy answer to a problem I am having.
I previously had been using the 30-day evaluation of LabView to start creating an application for reading data from an RS232 instrument output through the serial port on my laptop. I based this off of the basic serial read and write example and it was working fine.
Now, I have purchased the Basic Labview software, had downloaded the software and activated it. When I opened up the VI that had previously been working, it now will not read the data from the instrumen. - there is nothing showing up in the "read string" text indicator window.
I verified that the instrument and connection is fine by acquiring data in HyperTerminal - I'm using all the same data transfer settings in LabVIEW.
The instrument automatically prints / sends the data at specified intervals (I've had this set to 1 sec). No commands need to be written to the instrument.
I wonder if there is something with the LabView installation that requires the computer ports to be configured? The Visa Resource Name in the VISA Serial configuration is "COM1", as it had been previously. Does LabVIEW need to be instructed as to what "COM1" refers to? I did not have to do that previously, so I kind of doubt it.
I've attached the VI. Note that it is rather messy in the case structure for the serial read function, because I've been playing around with how to handle the data.
Thanks for any advice.
Solved! Go to Solution.
02-09-2011 10:16 PM
Why on earth would you flush the receive buffer when you are trying to do a read?
Also, disabling the termination character and using a fixed byte count to read is in general, a bad combination. /if the instrument sends a term character, enable it. If it doesn't, use the VISA Bytes at Serial Port.
02-09-2011 10:28 PM
Thanks for the input, Dennis.
There was some reason that I found flushing the buffer before each read made things work better. I think it was the only way I could each keep the subsequent read string to be in the right "frame" with the specified bytes to read. If I didn't flush the buffer first, the string would keep shifting. Changing the number of bytes to read from 26 only made it worse. I might be able to try a carriage return as a termination character and see if that solves the problem of not having things lined up right.
I'm obviously new to LabView and am trying to sort all these things out. The online forums and help files have made learning basics very easy, but some of the details of how to best do things are a little harder to figure out. I definitely appreciate the suggestions on this.
Any ideas why LabVIEW (after un-install and re-install) is all of a sudden not ablt to read from the COM1 port?
(For some reason I thought it might be best to first uninstall the evaluation version of LabVIEW before installing the Basic version I purchased, but it turned out that to download the software and activate my liscence over the internet I ended up first needing to download and install the evaluation version again. So that uninstall was probably pointless.)
02-09-2011 10:53 PM
02-09-2011 10:57 PM
Do you have a manual that you could attach?
02-10-2011 08:40 AM
Albert,
No, I cannot see any of my PC's ports under 'Devices and Interfaces' in the MAX configuration tree - In Fact, 'Devices and Interfaces' does not show up in MAX. Under 'My System', I only have 'Software' and 'Remote Systems'. Should MAX be detecting and displaying the ports from my PC?
I'm wondering if I should just uninstall and this time reinstall LabVIEW Base from my CD that was shipped to me instead of installing from the download from the NI website.
Another think I noticed, not sure if related, is when I try to place the 'Instrument I/O Assistant' on the block diagram (not sure what this would be used for, but just playing around), I get the following error message: "Measurement & Automation Explorer or the Instrument I/O Assistant is not installed correctly. Please install these from the LabVIEW driver CD." I had this error message before when my VI was working properly in the software evaluation mode, so I didn't think much of it.
02-10-2011 12:11 PM
02-10-2011 01:20 PM - edited 02-10-2011 01:25 PM
You will need to install "Device Drivers" this usually ships on a dvd with your software but you can also download it from the link.
Also double check the DAQmx version if you think you have installed Device Drivers. there was a incompatability in some versions that is known to cause devices to not show up in MAX with certain USB devices present
02-10-2011 01:35 PM
02-11-2011 05:49 AM
Turned out that uninstalling LabView and reinstalling from the CDs did the trick. It is again acquiring the data through the serial COM1 port. Not sure exactly what the problem was, but it is working. Now, back to trying to build my application. Thanks.
