06-27-2018 01:10 PM
What is the pin mapping for NI's serial cable 182845 ? I can not find a diagram. I would like to know if it is the correct mapping before I buy it. Looking for info along the lines of:
RJ50 pin1 --> DB9 pin 6
RJ50 pin2 --> DB9 pin 3
..., etc
06-28-2018
11:52 AM
- last edited on
08-06-2024
11:53 AM
by
Content Cleaner
Hey,
I found this article that might be of some assistance! It talks about some the pins.
Converting an RJ50 Serial Connector to DB9 or DB25: https://www.ni.com/en/support/documentation/supplemental/18/converting-an-rj50-serial-connector-to-d...
-Brian J.
06-28-2018 01:41 PM
Thanks for the link! That is a handy chart, but it appears to only describe the pin assignments for each connector type (and how they map to each other). Does anyone know if the 182845 cable is wired as a direct mapping (like the above chart)? Or are the RXD and TXD swapped, etc?
06-29-2018 03:20 PM
It really just depends on the cable. If the 182845 is the part number, what are the connection types and what is the serial protocol?
-Brian J.
07-10-2018 09:03 AM
I ended up buying the cable and measuring it myself. Here is the NI 182845 pin mapping for those interested:
RJ50 pin 1 --> DB9 not connected
RJ50 pin 2 --> DB9 pin 9
RJ50 pin 3 --> DB9 pin 8
RJ50 pin 4 --> DB9 pin 7
RJ50 pin 5 --> DB9 pin 6
RJ50 pin 6 --> DB9 pin 5
RJ50 pin 7 --> DB9 pin 4
RJ50 pin 8 --> DB9 pin 3
RJ50 pin 9 --> DB9 pin 2
RJ50 pin 10 --> DB9 pin 1
Note that the Rx and Tx lines are not crossed, i.e. this is a straight through cable. You will need a crossover cable attached to the NI 182845 to communicate with most serial devices.
