10-02-2006 06:58 PM
10-03-2006 10:55 AM
Doug,
What adapter are you using? Have you tried an alternate? I've done similar things with both NI USB-232 and BlackBox PCMCIA-232 adapters and never had a problem. I gave up on using several other adapters because of problems with the 3rd party drivers.
10-03-2006 11:01 PM
As long as the 3rd party USB-serial driver is installed as the system's virtual COM port, NI-VISA recognises the port and you can use it from VISA, LabVIEW, etc. However there is a fact that some products are causing problems are when using with NI-VISA. A small issue is that some baudrate or stopbits are unavailable, but the worst case is causing blue creen deth. (In fact I have a couple of 3rd party adapters and one of them causes blue screen when calling viRead() function.)
If you want to completely avoid the problem, you should buy NI's USB-serial adapter which is guaranteed to use with NI-VISA, though it is more expensive than others.
10-04-2006 07:07 AM
10-04-2006 08:09 AM
Doug,
What version of NI VISA are you running? I found this post and a fix that was made to NI-VISA
http://forums.ni.com/ni/board/message?board.id=170&message.id=142452&requireLogin=False
