ā01-11-2007 12:12 PM
ā01-14-2007 08:49 PM
ā01-16-2007 11:14 AM
Hi Daryl
I have followed the step you taught me and put the drivers on the right directories.
However, I am not sure how to use the instrument driver. What I mean is that there are many VIs there, and I would only want to use those VIs which are useful to download the trace from the OSA. Do I need to initialize, configure and close the instrment driver?
This might be easy for all of you but please spare some time to help me! Many thanks!
ā01-16-2007 11:51 AM
ā01-16-2007 01:56 PM
ā01-17-2007 06:05 AM
ā01-18-2007 04:56 PM
Hello Ryan,
I have modified the error handling of the ag8614x Download Traces.vi (screenshot attached). If you could adjust the error handling wires in that way to where it passes through the call library function node and take a screen shot of the errors that you are getting. If you moved the DLL to the same directory as the other VI's in the driver (the instr.lib folder) then this error should not be occuring.
Daryl E
Applications Engineer
ā01-18-2007 04:58 PM
ā01-18-2007 04:59 PM
ā01-18-2007 05:02 PM
