Passing a VISA resource name from a vi to another vi
Hi everyone,  I'm using a global variable to pass the VISA resource name from a initialisation vi to an execution vi of an application, the problem is that the resource name hardly ever appears on the execution vi even when the condition to go from the initialisation vi to the execution one is that in the first one there is a resource name. Any idea about this?
I'd appreciate every comment.
Best regards.
(3,682 Views)
This looks like a race condition. Are you sure that the execution vi really is executed aftr the initialisation vi?
Does the name come up in the global variable? And finally can you pass the vi or vi's with their main vi?
greetings from the Netherlands
(3,663 Views)
Accepted by topic author JEmmanuelH
The simple solution would be to not use the global variable and pass the resource reference out of the initialization VI and into the "execution" VI.  Then data flow will take care of the order.
(3,643 Views)
First of all, thanks for your comments.
I´ve realized that if I run the execution VI in Highlight Execution the VISA resource name is catched correctly. I'm going to try the option of crossrulz, anyway I'll leave the subVI's below just in case and if there is any reccomendation.
Thanks for all.
(3,629 Views)
Are you able to share image ?
(791 Views)
