12-08-2011 01:39 PM
We have NI interface boards:
NI PCMCIA-FBUS/2 Series 2 190143B-01 & Cable 183809-01 to allow us to communicate using PACTWARE to Fieldbus magnetrol units. In this case I want to hook up a PC and use pactware to pull echo curves off of the 705 magnetrol unit. Will my current interface board work for this and I just need a different cable or do I need a whole different set of equipment?
12-09-2011 01:53 PM - edited 12-09-2011 01:54 PM
Cordenuser,
I know National Instruments recommended the NI USB-8486 for newer designs, but I don't have any knowledge beyond that on the device you are currently using.
FieldBus products are specifically supported on the forum below.
http://forums.ni.com/t5/FOUNDATION-Fieldbus/bd-p/120
Sorry I can't offer more help, but you might have more luck posting there.
Best,
Peter Connolly
12-14-2011 12:13 PM
The equipment you describe should be sufficient. Here is the link for instructions on connecting PACTware (and the appropriated FF DTM) to a Model 705 transmitter with Foundation Fieldbus output.http://us.magnetrol.com/PDFs/1/59-601.pdf
