07-29-2013 03:23 AM
Dear members,
I would greatly appreciate if somebody helps me out the issue im faceing.
We bought NI PXIe 8431/8 Serial device and I tried to install its driver on win 7 after setting the hardware properly (put the pxi 8431 on 2nd slot).
Everything passed ok when i installed s/w provided by NI and after finishing it asked me to restart computer and i did.
Computer finds PXIe 8431/4 exactly by its name. Hoverwer the problem is it has 8 ports, nothing appeared.
I mean I had to able to have 8 port to open but no ports available.
And I did this steps on Win XP and everuthing is OK. I can open 8 ports and write/read.
Could you pls tell me what is problem with Win 7? On the disk of the PXIe 8431/8 there is written that win 7 supported.
No idea what to do... I cannot downgrade my OS cuz its licenced.
Thanks a lot.
07-29-2013 12:49 PM
I assume you are running NI-Serial 3.5.1 this version Does have support for Win7. Support for PXIe devices was not added until version 3.6. available here
07-29-2013 06:39 PM
Thanks for reply, Jeff.
But Im trying NI-serial 3.9.1 version. Forgot to post version.
07-30-2013 12:57 PM
hmm , This sounds very odd.
Can you post snips of device manager ports and MAX ports?
