11-10-2021 11:54 PM
What is the thread pitch/screw size for the holes next to the Thunderbolt 3 ports on the card? Are there any readily available retaining clips that are compatible? Thunderbolt 3 is great but in a busy production environment it's easily disconnected or damaged with a bump or tug. I think the larger one is 4-40 but not sure about the smaller hole.
11-11-2021 08:37 AM
I think you need to get this cable retainer - I would assume these are compatible as Thunderbolt cables are fairly industry standard.
https://www.sonnettech.com/product/thunderlok3.html
11-11-2021 04:12 PM
Santo_13,
Thank you but unfortunately the screw for the Sonnet is a 4-40. The screw hole on the side is smaller. I've looked through various manuals and forums but have not found a single mention of the specs or any hardware made for this. There has to be something, thank you again.
11-11-2021 05:35 PM
Well, that is rather surprising, there is no trace of documentation of that screw.
You will get an answer if you contact NI Support
11-12-2021 08:23 AM - edited 11-12-2021 08:24 AM
That's an M2 nut above each connector. The holes at either side are 4-40
- Robert
11-18-2021 05:05 PM
Thank you!
