I have a NI PCMCIA GPIB card. The computer will recognize the card in the system tray but the 488.2 Measurement and Automation program doesn't see the card under Devices and Interfaces selection. Also in the Windows Device Manager it has a yellow exclamation and is attached to National Instruments GPIB Interfaces. I'm using a PCI to PCMCIA Controller Card model# Ricoh RL5C475 and in Device Manager under PCMCIA socket it lists two, a PCMCIA Card Services and the RIcoh RL5C475.
The GPIB Card in Device Manager under Properties it says the drivers for this device need to be reinstalled (code 7), but I have tried this already.
In Device Manager under Resources it says this device isn't using any resources because it is not currently enabled or has a problem. If I select Set Configuration Manually the Conflicting device list shows some conflicts. The I/O Range is automatically set at 0000-001F and the Interrupt Request is automatically set at 00. The I/O Range is conflicting with Motherboard resources and Direct memory access controller. The Interrupt Request 00 is conflicting with the System timer.
Can you help me in clearing up the I/O and IRQ conflicts to allow the card to work properly? If you don't think that this is the problem please list some other possible causes.
Thank you.
