06-03-2011 10:26 PM
I have a PCI-GPIB card and I am having problems communicating with the SR245.
I have checked and read all the forums and was not able to find a solution. My SR245 is less than 6 months old so I don't think the solution using the 270 pF capacitor applies to my problem. Using Measurement and Automation, I can see the device with its respective GPIB address. When I try communicating with it, I get the EABO error.
I would appreciate any help. I will try using a shorter cable length tomorrow as well. Thanks in advance.
06-04-2011 01:32 PM
fixed the problem.
seems like trying to communicate with MAX messed up the SR245, changing the GPIB address solved the problem. I opened up MAX again to see if it was simply because of a GPIB address conflict with another device but got the same error and it stopped working again. Changing the GPIB address of the SR245 solved the problem again and now I am forbidding myself in opening MAX ever again.
Think tank, Thunk!
