Omega HH506RA datalogger thermometer serial com commands?
Thank you very much for your help!
My code is currently working even if there's still some error (I used the simple error handler to keep track of errors while the program still run until the end)
Olivier
Message 11 of 14
(3,475 Views)
FakStory,
How were you able to change from the special characters to meaningful temperature numbers?
I am using an Extech 421509 which uses the same command structure as the HH506ra, but I can only read the special characters.
Dan
Message 12 of 14
(3,209 Views)
Hi Dan10,
                It's been 2 year ago and I don't fully remember... What do you mean by special characters? Is this what you got directly by the serial port? Make sure you're reading the correct format... HEX or ASCII...
Fakstory
Message 13 of 14
(3,162 Views)
Hi FakStory,
It turned out to be a problem of how many bytes I read. There are still acouple of glitches but I wrote some code that just repeats the measurement if the glitches happen.
With that it works fine now.
Thanks!
Message 14 of 14
(3,010 Views)
