10-15-2012 04:22 PM
Chemist189,
nyc was referring to our Version Conversion page. Feel free to save the code and upload it to the discussion forum if you want to view it in LabVIEW 7.1. I must stress that johnsold has provided a good amount of information on this issue, so please feel free to indicate a specific question related to Omega CN7500 communication.
Best,
10-16-2012 02:39 AM
Thanks both, for informing me about the Version Conversion board - sorry, I'd somehow never been aware this existed. Thanks again.
10-19-2012 05:41 PM
Hi All,
I've taken much of ChE3208's code and developed a small instrument driver for the CN7500 temperature controller. The instrument driver allows you to monitor the process value, set point value, and front panel LEDs from the controller. It also allows you to send set point values to the device. This instrument driver is setup to help you get started using the device and does not cover every functionality available on the controller. I have included an example as well. Please ensure your device's serial configuration matches the configuration in the code for the example to work correctly.
The attached instrument driver was created in LabVIEW 2012. Please note this driver has not been verified by NI or Omega. I can convert it to an older version if need be.
Hope these are able to help someone out.
Cory
03-18-2013 11:20 AM
Greetings.
I need this communication, but I have LabVIEW 2009, you can download the version.
thanks
03-19-2013 04:33 PM
I am not sure if you meant to ask a question or stated a response. Please clarify.
Also, I would recommend generating a new thread as this one has been inactive for 5 months. New threads are actively monitored by forum members and can get a much faster response.
You can reference this thread in the new one.
Regards
03-19-2013 04:53 PM
Sorry I have not answered sooner. I assume you wanted me to convert the files to LV 2009. Please see attached zip file and see if this works for you. The files were saved for LabVIEW 8.6.
Hope this helps.
08-12-2013 10:59 AM
Hi, I was wondering if you could convert your driver to labview 9.0 as well.
08-12-2013 11:01 AM
Ignore this post, I just saw that it has already been addressed
08-12-2013 11:43 AM
Forgive me if this is an elementary question: I am using the Omega cn7500 hooked through an NI DAQ board. How would I tell the controler where to read and write from? (How would I specify in the program the physical channel that I have the temperature controler wired to?)
08-12-2013 11:49 AM
I don't think you can run the CN7500 through typical analog and digital I/O channels. These temperature controllers communicate over RS485, so you will need to get an RS485 to RS232 converter (from B&B Electronics or other mfg.) to allow you to connect to your pc.
