Obtaining an IVI Driver Session from IVI Logical Name in IVI-COM
Hello everyone,
I was wondering if someone can help me understand a few things. I am writing a program in C# using a C DcPwr library. I read that I can use the DllImport function but I'm having some trouble understanding some things.
The function I'm importing is
ViStatus _VI_FUNC CPX400_init (ViRsrc resourceName, ViBoolean IDQuery, ViBoolean resetDevice, ViSession *newVi)
so I'm confused about two things
The first things is the _VI_FUNC. Can someone explain what that does and how it interacts with the C code.
The second is importing the C function into my C# application. How do I translate the declared types to C# types? I assume I can change ViBoolean to bool, and maybe ViRsrc to string, but how about the others? If I'm wrong, please let me know.
(3,196 Views)
All of the questions you are asking are about typedefs and definitions. Probably on your computer is a visatype.h file which shows definitions of _VI_Func as well as all of those data types. For example, I have a copy of this located in C:\Program Files\IVI Foundation\VISA\Win64\Include.
For example, depending on your processor, if you are running Windows 64 bit, _VI_Func gets defined as a _fastcall function type, but if you are running Windows 32 bit, then _VI_Func gets defined as a _stdcall function.
To go further, this visatype.h file also defines unsigned short as a ViBoolean. So that would show which filetypes you can use when transferring over to C#. You could try using the original data types instead of the custom typedefs, but if you run into issues then it might be easier to create a C wrapper which converts your C# inputs into the typedef parameters.
Best,
Shamik C
http://www.ni.com/support
(3,152 Views)
