06-08-2018 01:44 PM
Indeed it was, I have correct it based on the manual, still no change
@AnalogKid2DigitalMan
06-08-2018 04:31 PM
Hello again,
How are you sending the commands? Using LabVIEW?
06-08-2018 04:48 PM
Hello again, thank you for your continuos assistance, I´m sorry for my lack of knowledge,
I have a VI for serial communication that I know works (I havent used it yet, wouldnt work), I´m first trying to make it work in NI MAX, in the VISA test panel with the I/O.
06-08-2018 05:28 PM - edited 06-08-2018 05:37 PM
You don't have a sample that can be .exe that works?
With that we could sniffer the bytes and check were the problem is.
I can see that they have LabVIEW drivers. The sample in LabVIEW also should work.
The first command that you can send is the address:
"The address (“ADR n”) command must return an “OK” response before any other commands are accepted. 7.5.1. Data Format Serial data format is 8 bit, one start bit and one stop bit. No parity bit. 7.5.2. Addressing The Address is sent separately from the command. It is recommended to add 100msec delay between query or sent command to next unit addressing. Refer to Section 7.7.3 for details. 7.5.3. End of Message The end of message is the Carriage Return character (ASCII 13). The power supply ignores the Line Feed (ASCII 10) character."
06-11-2018 09:30 AM
I´m using a modified version of the serial example of labview, but I´m not using it, I´m trying to get a response in NI MAX.
@Jorge_Amaral I can see that they have LabVIEW drivers. The sample in LabVIEW also should work.The first command that you can send is the address:
If I use the program just like this, there´s no response, it just waits indefinitely.
Could my power supply be the one with malfunction?
06-11-2018 09:52 AM
I can't be sure but my bet it's that the power supply is ok. And the typical problems ate:
1. Cable (really important to be sure)
2. Serial Settings
In the PSU you also need to be sure about the id (usually is only necessary in rs485).
I also had some problems with usb to rs232 converters. The voltage level were incorrect.
06-15-2018 05:16 PM
Have you Found a solution?
Br,
Jorge Amaral
06-18-2018 11:35 AM - edited 06-18-2018 11:43 AM
Sorry for the delay,
No I havent, my boss is an admin and hired another engineer just as lost as me,
we are still trying to find a solution.
No advances yet.
