No Visa resources found - 0xBFFF0011 (VI_ERROR_RSRC_NFOUND)
I see this on my Max. I read few posts but they were unrelated. I am running Windows 10 64-bit, LabVIEW 64-bit, and MAX 19.0.0f0.
I uninstalled NI VISA and reinstalled but problem won't go away. Any thoughts?
Screenshot attached.
(6,749 Views)
How about some more information:
  • Manufacturer and Model of instrument
  • Communication port used (USB, GPIB,...)
  • Any converters used (USB-to-GPIB,...)
  • Port configuration (for Serial,...)
  • Any other useful information about the equipment trying to be detected
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(6,732 Views)
This is with no HW connected. But even when i connect HW, it shows the same error as the screenshot from my original post. Anything help of help?
(6,730 Views)
Adding this screenshot that might show the problem better.
You can see COM3 on device manager, but on Max, its absent. I have both NI VISA 19.0 and NI Serial installed. Thoughts?
(6,718 Views)
Accepted by topic author winterishere8
I ended up uninstalling LabVIEW and all NI stuff and re-installing and it fixed the issue x-(
(6,695 Views)
