11-07-2019 06:13 PM - edited 11-07-2019 06:48 PM
Hi all - a newbie here with a problem
I got a vintage (the board is dated 1988) GPIB-232CV (not -A) 64K adapter that I wanted to use to connect my HP 7475A plotter to a modern PC. I connected power to the adapter today to test it - it came on with all LEDs fully lit up. After around 2-3s I smelled smoke, so I disconnected quickly.
I openned the case and it seems the board is in a good condition, but one of the capacitor has blown (seen in the photo in lower right - C40). I am hoping to fix it (can't afford a new adapter on a student budget), but it seems I can't find a service manual for this particular model (the model doesn't even show on NI website). I am hoping someone has a copy of a service manual or know what capacitor was at C40 so I can replace it.
I suspect the core problem was a faulty power supply, so I am hoping to get a modern PSU connected after I deal with the capacitors. However, maybe all the LEDs being lit up on power on is a known code that points to some other issue.
Any help would be greatly appriciated.
Edit with some more (possibly helpful) into:
Device name on the bottom label: GPIB-232CV 64K
Part number on the case: 180455-01 rev b
Part number on the board: 180367-01 rev b
S/N: 356
11-07-2019 08:52 PM
Sorry for replying to myself, but I can't edit the original post anymore...
I would also love to know what size plug would I need for the power supply - it doesn't seem to be included in the user manual (maybe it can be found in service manual?).
11-16-2019 10:46 PM
An update, as others might find it helpful in the future.
After getting some help from other engineers and analyzing the board, we have identified that the C40 cap is 99% the same as the one on C18. Those are the only two components that share shape and color, and the drawing on the board is the same. After de-soldering C18 we have found that it can be replaced with: T322A105K025AT7200 from KEMET.
Also, it seems that C40 is there to reduce noise on switching, so it is not essential.
After soldering c18 back on and getting a new power supply it seems the board is working (power, ready and listen lights stay lit) - I am waiting for a cable to confirm 100%
The manual says that power & ready should stay lit. Is it normal for LISTEN to also be on when nothing is connected either to serial of GPIB in controller mode?
11-19-2019 05:51 PM
I got all the cables needed, but I am unable to connect to it via Serial. I have few questions and hope someone who has a GPIB-232CV can answer those:
