07-27-2007 04:36 PM
07-27-2007 04:53 PM
First, you don't need a DAQ board. All you need is the GPIB controller. The instruments take a measurement and return the results over the bus.
For the rest of your question, I would suggest you go to http://www.ni.com/devzone/idnet/ and learn something about LabVIEW and instrument drivers. All of your instruments have drivers available for them and that will make your life a lot easier. Most, if not all, of the drivers will include a high level example VI to get you started. Another thing that I recomend is that you study the instrument manuals and learn how you configure a measurement manually. If you get familiar with the instrument front panel controls, then it's easier to relate that to the remote control commands that the drivers will issue.
07-27-2007 04:56 PM
Thank you Dennis. I will follow that. and if I need anything iwill post it on this board. Its good to know that I dont need a DAQ card. I appreciate your help.
07-27-2007 05:44 PM
07-27-2007 05:55 PM
Thanks, I was going through the same,
I tried to communicate with E34401A and it gives me error I put *IDN? query request, then did a write and a read and it gives me error on the dispaly of 34401, i am unable to comprehend it.
07-28-2007 12:37 AM
