08-31-2011 06:40 PM
I am using LabView 8.6 on a PC running Windows XP. I have a series of LabView VI's that I have used for years with a borrowed (older) GPIB-USB interface connecting to my instruments. I recently gave the older interface back to my friend and purchased a GPIB-USB-HS (the only option from NI). Today I tried to run one of the programs, which talks to a few instruments, in particular a Keithley 238 SMU, on which it slowly increases the current value while taking a measurement on another instrument. The program sets a value from 0, increasing by 1mA steps up to 200mA - it has always worked fine before. Now, it runs for a while (varies from e.g. 6 to 54 steps) and then has an error (Code 6, GPIB Send) and gets tied up at that point. I tried the VI that just sends the current value to the Keithley 238, and it does the same thing - I can run it multiple times but eventually it times out with the same error (code 6).
I have tried removing instruments and GPIB cabling, restarted muliple times etc, to no avail. I wonder if there is an issue with the interface trying to run in high-speed mode? - the data sheet mentions a HS mode with noninterlocked handshake, could this be the problem, and how would I turn off the high speed mode if it is? What else could be the issue - short of a bad GPIB-USB-HS interface?
thanks, Paul
09-01-2011 10:33 AM
In MAX, you have the option to change the bus timing. You could try the slowest setting. Sometimes this is necessary for older instruments.
09-01-2011 10:51 AM
I tried modifying the advanced settings yesterday, setting Bus Timing to 2microseconds (slowest), also I played with the HS488 cable length, tried it off or 15meters. I just repeated the test with Bus Timing 2us, HS488 cable length off. I get the same problem, works for a while and then I get the code 6, GPIB send error which ties up the VI.
I am running an older version of NI-488-2 (version 2.5.2), which says it supports the USB-GPIB-HS interface (in Read Me file). I have the newer version disk (version 2.7.3) that came with the interface - is there any reason that this should work better? (I prefer to change as little as possible when things are all working...)
thanks
09-01-2011 02:05 PM
OK, I updated NI-488-2 to version 2.7.3, still the same problem. I also tried the interface plugged into an external USB hub rather than directly into the computer, again, no difference. Is there something else I can try or change?
09-01-2011 03:06 PM
this device uses the max power, so it is good that you tested with external power.
Also the bustiming on 2Us is OK.
I would also switch off automatic polling (parallel is probably switched off, do it also for serial polling)
How long does it take before the system fails?
09-01-2011 04:28 PM
OK, I switched off automatic polling and it behaves the same. It takes a different (random) number of times running the routine to send a value to the Keithley 238 SMU, sometimes one of the first values, sometimes over one hundred values are sent before it goes wrong. With the old (GPIB-USB) interface I never once saw this problem.
09-04-2011 08:36 AM
09-04-2011 09:20 AM
I am only incrementing every 3 or 4 seconds - that should not seem to be an issue.
09-04-2011 09:42 AM
