03-15-2021 04:02 AM
It's seems to have bug in module nidaqmx in python to control the channel in output
The read function for channel configurate in output digital seems to work only for port0/line0:3
I'm not sure but it's seems that moreover the output digital comes is replaced by a input digital when a read is performed.
if you launch my program below you will see that
print(f"do_read : {do_read}") indicate 15,, so only the port0/line0:3 is changed and on the board NI6501, the situation is confirmed
If you remove the line " read" from the code, all ports, port0/line0:5 is modify on board
I see also that the nidaqmx has not been updated until 2017. Is it normal ?
import nidaqmx
from nidaqmx.constants import LineGrouping
dev_str = "Dev1/port0/line0:5"
# nidaqmx.do_output_drive_type = nidaqmx.constants.DigitalDriveType.OPEN_COLLECTOR
with nidaqmx.Task() as task:
task.di_channels.add_di_chan(dev_str, line_grouping=LineGrouping.CHAN_FOR_ALL_LINES)
task.do_channels.add_do_chan(dev_str, line_grouping=LineGrouping.CHAN_FOR_ALL_LINES)
# task.do_channels.do_overcurrent_limit = 0.0001
# print(f"Drive type avant : {task.do_channels.do_output_drive_type}");
for chnl in task.do_channels:
# chnl.do_output_drive_type = nidaqmx.constants.DigitalDriveType.ACTIVE_DRIVE
chnl.do_output_drive_type = nidaqmx.constants.DigitalDriveType.OPEN_COLLECTOR
print(f"Drive type après : {chnl.do_output_drive_type}");
task.start()
task.write(15+32+16)
print(f"do_write ");
# print(f"do_is : {do_is}");
do_read = task.read(number_of_samples_per_channel=1)
