According to the data sheet/manual, the I2C pins can accept up to 5.5V. So as long as the voltages don't go 10% too high, you should be fine. You will need to supply your own pull-ups for those lines.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
