08-08-2018 10:11 AM
I don't know if this is the appropriate board.
So I'm using a PXIe-2529 switch with a 4x32 topology.
I've created "Routes" using the Switch Executive tool that I plan to pick from a teststand sequence using IVI Switch step type.
I'm wondering how to deploy that on my client station and be able to display those routes if we need in NI MAX. Do I need a special "runtime" version of NI-Switch installed or such thing.
Ideally I would like that somehow shown in MAX without the possibility to Edit those routes, in read-only so I have the confidence that my customer can't break the routes by mistake and my code runs properly.
Using my development PC I Export those routes to a *.nce file and import them on the customer PC, from there we can see what the routes are without having rights to edit them.
Does it make sense?
Thanks for reading
Solved! Go to Solution.
08-09-2018 04:00 PM
08-10-2018 09:34 AM
Oh god I wish I found that myself.
I'm a bit shocked the runtime is not free, but somehow it makes sense.
Thanks a lot!
