12-16-2019 06:10 PM
I bought the NI PCIe-8430/8 and installed the drivers that came with the cd. The device and the COM ports show up correctly in device manager and NI Max but the NI-Serial Troubleshooter fails when it tries to identify each COM and if I open the device in NI Max it fails the self test. I also cannot talk to equipment over the COMS listed. Is there something I did wrong?
12-24-2019 09:26 PM
01-02-2020 02:22 PM
I talked to NI Support about this issue and reinstalling NI Max, NI visa, and NI Serial helped resolve the problem.
01-02-2020 07:33 PM
Hi JohnSutton
I wonder if you care about the level of the output signal, whether you have used an oscilloscope to measure the level of the idle state of the signal on the line. I used the board card as 485 and set the transceiver mode to 2-wire auto. When I measured the output signal with an oscilloscope, the idle state level on the line was 0v, which should be logically high in theory to avoid interference. Looking forward to your reply.
