03-13-2018 09:29 AM
Upgraded to LabVIEW 2015 from 2013.
Have been using Name in NIMax to name my instruments rather than used the VISA Resource Name.
ie. counter instead of GPIB0::3::INSTR
This has been working fine until I upgraded.
I still see the name in NIMAX as 53132A"Counter" with VISA Resource Name as GPIB0::3::INSTR
If I search or refresh for the Name 'counter' in LabVIEW it does not appear. However, I do see GPIB0::3::INSTR in the drop down.
There are about 60 vi's in my code I will have to change to read the VISA Resource Name instead of using Counter. This is not the only instrument this is happening with. Any ideas?
03-16-2018 03:03 PM
Since the program was working fine until you upgraded, I think you should check the compatibility of your drivers with your new version of Labview. Check the following documents:
I hope this helps!
08-21-2018 12:14 PM
Sorry for the delay. Since I posted this, I seem to have worked it out. Can't remember what I did to resolve it. But for now it is working.
