NI 9234 and 9264 synchronization issues
Dear all,
I have a NI 9264 analog output that is connected to a current control board and a NI 9234 analog input installed on a cRIO-9024.
Basically I specify the current I want to output and I measure the voltage using the NI 9234 analog input and do a division to measure the current.
However, there seems to be a synchronization issue that can be visible when outputting a sinuosidal current to a 100 ohm resistor that results in the result of my VI displaying a sinuosidal resistance. Since I'm pretty new at LabVIEW, I have no idea what tutorial to learn from in order to begin solving this problem.
I attached the project, VI and an image showing this synchronization issue.
I would deeply appreciate any pointers towards solving this issue.
Message 1 of 1
(4,228 Views)
