NI-488.2 no download possible
NI referred me to the NI community. I have a GPIB-USB-B and a GPIB-USB-HS device.
To switch from Win 7 to Win 10 I need the driver Ver 17.6, unfortunately I can't download it from the NI site, nothing happens! What am I doing wrong
thank you in advance
Walter
(3,543 Views)
https://www.ni.com/de-de/support/downloads/drivers/download.ni-488-2.html#442610
I got this link from NI, no function
(3,515 Views)
In that link select the correct file. The lowest one is 17.6 in the select window when you click on the version.
(3,509 Views)
If I set everything correctly and press the DOWNLOAD button, it turns green and nothing happens?
(3,499 Views)
I got the correct download and via this link I even could download it again
https://www.ni.com/en/support/downloads/drivers/download/unpackaged.ni-488-2.306147.html
(3,491 Views)
Accepted by Zth_Walter
SUPER, your link worked, THANK YOU
. instead of #
(3,489 Views)
Can you provide a similar link for someone trying to download the Windows 18.0 Full 32-bit English driver? I'm having the same problem; when I input my download preferences, the download button does not take me to a download page.
(3,127 Views)
