NI 488.2 libnipalu failed
I have installed the driver NI 488.2 successfully, but when I open the application, I got the following error constinuosly:
"The attempted operation failed. libnipalu.so failed to initialize. Verify that nipalk.ko is built and loaded."
Some info:
CentOS Linux release 7.9.2009 (Core)
NI 488.2 v. 21.0
$ uname -r
3.10.0-1160.76.1.el7.x86_64
$  dkms status | grep nikal
nikal/22.5.0f45, 3.10.0-1160.76.1.el7.x86_64, x86_64: installed
$ dkms status | grep nipal
nipalk/22.5.0f43, 3.10.0-1160.76.1.el7.x86_64, x86_64: installed
(848 Views)
Dear anna314,
I've found a forum post with a similar issue, check it out : https://forums.ni.com/t5/Linux-Users/libnipalu-so-failed-to-initialize/m-p/3419908.
Also you can try posting your issue in NI Linux Users Community, as well. They usually are very active.
Best,
anasei.
(807 Views)
