09-19-2018 01:29 PM
I'm having problems getting my NI GPIB hardware operational on Win 10x64. This hardware worked fine previously on win10x64, but I had to reinstall the OS as my disk died. I took the opportunity to download & install the latest NI-488.2 v17.6 & NI VISA v18 from the website. I installed both these (can't remember which order I installed in), but could not see the drivers loaded properly in device manager. Re installing the NI-488.2, I get a message saying that the NI-488.2 Runtime 17.6 (64 bit) installation has failed.
I uninstalled everything using remove all button in the NI manager & installed NI-488.2 version 17 which I was previously using before I had to replace my disk. I get a similar message. Any ideas? Its driving me nuts.
The GPIB hardware is a PCI NI card, but I've also tried with a GPIB-USB-HS with the same result. Apart from the error message indicated above, the drivers don't install.
Thanks for any help on this.
Joe
09-19-2018 02:32 PM
Generally when you re-install Windows 10 you need to install the drivers starting with the chipset.
Always the case with the PCs I have from Dell, HP, Lenovo, Acer.
good luck
09-19-2018 03:05 PM
The only stuff showing driver problems in device manager are my NI products. These are my PCI-GPIB card, my DAQ card and a GPIB-USB-HS (bought from NI) when the latter is inserted. I've not tried to install DAQmx yet, thats a 2Gb download....
All chipset stuff, sound, graphics etc are fine.
Joe
09-19-2018 09:31 PM
Joe
If you say so.
09-20-2018 10:55 AM
Hi Joe,
Is the hardware itself appearing in either device manager or NI MAX? It may be a case of pointing windows towards the correct driver for
the hardware if it is trying to use a generic driver. Alternatively you can try to force reinstall the software you believe is causing issues.
Jonah W.
National Instruments.
