NI-4851 and TI TMP275 I2C temperature measurement
Hi everybody,
I want to read the Temperature of a Texas Instruments TMP275 (http://focus.ti.com/lit/ds/symlink/tmp275.pdf) I2C Sensor with a NI-4851.  After some tries i was able to read out the correct temperature: read.jpg
at the next step i wanted to increase the resolution by sending a 01100000 to the sensor to activate the 12 Bit operation mode, i used a shrinked version of the write example:
but then i get this error:
what do i do wrong?
best regards
Message 1 of 8
(6,403 Views)
Accepted by topic author N.Schnitzler
Message 2 of 8
(6,398 Views)
Thank you,
i think i skipped the important passage at the datasheet, now it works fine.
best regards
Message Edited by N.Schnitzler on 05-20-2010 06:26 AM
Message 3 of 8
(6,386 Views)
Glad you got it working...:smileyhappy:
Message 4 of 8
(6,381 Views)
I do am a beginner and I need to read the TMP275 through the NI8451 with 12bit resolution.
Can you show the VI to configure and read with max resolution?
Salvo
Message 5 of 8
(6,069 Views)
i will be at my office on wednesday, then i will search and upload the files.
best regards
Message 6 of 8
(6,037 Views)
here is the configuration and the read out file, not nice but working.
best regards
N. Schnitzler
Message 7 of 8
(5,983 Views)
Thank you very much!
Salvatore Caruso
Message 8 of 8
(5,980 Views)
